OK, Got an MSI X570 Tomahawk board with Ryzen 5600x and was using with GTX 1080 until i decided to sell the card, bought a cheap GPU until i eventually got a RTX 3070 MSI Ventus 3x.
After installing, it booted and went very slowly into windows, looked like the FPS was so slow you could see the banding go down the screen as it refreshed loading the desktop background (even done the same in BIOS). Installed NVIDIA drivers and cleaned out old ones with DDU etc, still wasnt right.
Now, went in and changed card into different slow and it worked fine, ahh, must be PCI lanes i thought, thus went into BIOS set lanes to GEN 4 manually, swapped back to x16 lane, rebooted and fine. Played Games no problems, super fast , worked as expected. Went into sleep mode, rebooted fine etc. I had thought the issue resolved....
On a couple of more reboots the issue surfaced again, i went back into bios and moved the settigs around again and put back to what they were, saved and rebooted and it went fine again after loading in windows etc. I have flashed to the latest BIOS on the board.
Really odd, could be a power supply issue (650w gold EVGA G3, this should easily take the GPU and chip) or a BIOS issue of incompatability. I wouldnt have thought its a PCI lane issue as previous GPU worked fine unless it has occurred during installation. It might be a GPU issue but i would have thought you wouldnt get into games and run at full pelt if that was the case.
Any thoughts as its bloody odd, it almost feels the whole system is slowed down when the issue occurrs?
WH
WH
