Weird Issues {thoughts advice?]
9 Dec 2006
@ManCave
So last few weeks been having this issue with my PC.
Firstly This happens at Stock or Overclocked (CPU) i don't OC my GPU
5930K
1080GTX - newest drivers
So On my Main screen ill be playing a game, lets say Overwatch at a constant 100FPS
On my right screen ill have chrome open
Every so often i alt+tab use chrome etc.
Every so often after 5 mins after alt-tabbing my games Flickers Really quick, almost like your changing resolution in game. then FPS tanks. i'm talking 100FPS to 60FPS it also feels like The Refresh rate changes too as it feels stuttery/jerky
Then i exit the game, Windows UI can be unresponsive for 30-3 Minutes, any actions are saved up and done at once. After this period its fine again... relaunch gaming = perfectly fine
thought it might be memory related, but i only have this issue in games, nothing else.
Any Thoughts?
Already done clean Driver Install
Stock Settings
CPu TEmps 58C
GPU temps 68C
5930K
Any Thoughts?
Stock Settings
CPu TEmps 58C
GPU temps 68C
Have you tried another set of memory?
Maybe a clean windows install?
normally running is
HWINFO
Afterburner
CHrome
Thats it
only played overwatch recently so only on this so far
i think its related to chrome some how.... maybe hw acceleration is not going back to the game
normally running is
HWINFO
Afterburner
CHrome
Thats it
OK, I would try a different browser for now then. Remove chrome completely, use Firefox or something and see if the same problem happens.
If it does I suggest stopping each service that relates to a running application one at a time until you don't get the issue anymore.
If that doesn't work then you are going to have to start swapping out hardware, start with your monitors and then your GPU.
If that doesn't work then you have missed something from the above steps ;). Good luck and btw I'm loving your Man Cave thread :)
