weird problem with ipod nano
13 Dec 2002
Newcastle upon Tyne
Hi
My wifes nano is acting itself, not sure which one it is think its the 5th gen, small dinky squarish one that plays video.
Anyway it hadnt been used in probably 8 or 9 months she then decided she wanted to get some music sorted on it for our holiday in a few weeks time
Obviously it was dead as a dodo I had to leave it connected for quite some time then all of a sudden it came into life, it seemed to be ok until she started to try and sync then it just dissapeard from itunes and isnt listed in my computer either at first i thought it might just be the cable, but i bought another and its the same, its getting power to it as you can see the battery icon change the charging status but i just cant sync it, tried it on a few pc's no difference. Maybe the socket is damaged but just the pins for syncing?
Any ideas?
