1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Weird problem
Discussion in 'General Hardware' started by AlanJ, 6 Jun 2006.
  1. AlanJ
    Hitman
    Hi there,
    Seems ive run into a strange problem. My CPU is at 100% all the time!? Is there a way to find out what processes are running? Also Alt+ctrl+del isnt working.
  2. bbreezeuk
    PermaBanned
    sound like u have some sort of virus m8 try restoring your system to an earler piont
  3. senorstealth
    PermaBanned
    Does sound like a virus, if so restore will do no good
  4. bbreezeuk
    PermaBanned
    yea it will, if not try www.avast.com as they do the best free AV software
  5. 2bullish
    Hitman
    Errm no it wont, the virus (if thats what it is) will still be on tyhe comp no matter when you restore it to, as by definition it is stored in the "restore points directory"
    Turn off restore point, then run your AV, however, Im not convinced its a virus.
    Can you open up task manager by just right clicking your task bar?
    Download Hijack this if you want to find all your active processes, this will also tell you what should and shouldn't be there.
  6. StefanHolmes
    It might not necessarily be a virus. Choose 'Start -> Run' and load 'taskmgr' to see what's using all your CPU.
    There are a bunch of online virus scanners, Google is your friend ;)
