Weird problems - clueless
Status
Not open for further replies.
27 Jan 2018
I'm having a few problems and im not sure where the issue is coming from.
1.My graphics are fans aren't spinning sometimes which is causing the GPU to heat up to 94c. I have downloaded MSi afterburner and that has helped but still gets over 70c.
2.PC freezes (doesn't matter on what i have open) at really random times. I have to hard restart or shut down.
3. PC doesn't shut down properly? Every time i boot up, it opens my internet straight away with the last tabs i had open? This happens without me even clicking on the link.
4. Sometimes the case fans still runs little while after the PC has shut down.
Not sure what component is faulty? I am on windows 10
AVG and Malwarebytes found no errors apart from PUPs which are cleared and haven't resolved the issue.
Well, do you even know what parts you have there?
Anyway number one sounds like Nvidia having done buggy driver.
Nvidia has few times done drivers which have caused fan not running problems even burning some cards.
Status
