Weird PSU problem
26 Mar 2004
Old computer was switching on but nothing comes up on screen.
But the PSU would emit a hissing/humming sound before i've even pressed the power button on the PC.
So I tried a Corsair CX400 from my other PC. But all i get is the PSU fan spinning fro a second then off. And then the PSU fan starts switching itself on for a second then off again with no input from me. And continues to do so even if I switch it off from the PSU switch.
Only if I disconnect it from either the mains or the motherboard does it stop.
But then I tried a cheap (as in £10) 300W PSU and it switches on with no problems and everything appears on screen.
I was planning on installing a good PSU, not this cheap one. Any idea whats causing this problem?
what you describe with the CX400 sounds like a short, maybe try it outside the case, its possible if theres a short the built in protection on the cx shuts it down to save any damage, where as the cheap PSU prob doesnt have the protection built in
Thats what i'm thinking. Corsair has protection the other one doesn't.
It currently is outside the case.
Could a component cause a short. Like a graphics card, CPU or ram?
None of them are connected directly to the PSU but could they cause a short in the motherboard?
