Weird ROUTE problem?
10 Mar 2003
Hi,
Basically I have a very strange route problem.
We need to add a route to a specific range and if I do this on Windows Vista it works fine. However, on Windows 2000 and XP, it fails.
Any ideas? Is there an update route for Windows 2000/XP perhaps?
M.
The route fails with error message:
The route addition failed. Either the interface index is wrong or the gateway does not lie on the same network as the interface. Check the IP address table for this machine.
With Vista using exactly the same command it works fine.
M.
There must be a subnet mask difference between those two machines or something like that.
when specifiying routes you are specifiying the next hop, which must be reachable in one hop i believe
