weird traffic shaping, how to get rid of it?
2 Aug 2004
so ive been having a bit of trouble. for some reason this computer appears to be traffic shaping. most specifically whin a try an upload thinngs to google drive it goes slow as hell, for no reason that i can see. whats more i know its not my isp because if i do the same thing on my media computer it goes much much faster. the problem therfore seem to be this computer.
i have tried multiple browsers, google drive directly and all are the same so i think it must be my network card doing it but i cant see why.
any ideas? this is driving me mad.
Looking at your motherboard, it has something called Network iControl? Tried uninstalling that if you have that installed?
Go to network settings, and check what the sync speed between your PC and router is. Is the media PC syncing at the same/higher speed? I assume both are wired?
correct, both are wired, both 1gb connections and a can move data between the computers at hundreds of mbits so there isnt any problem there.
i should probably also note that if i run a speedtest i get this
so the connection is fine but if i upload thins to google drive its back to really slow, on this computer.
This will happen when your upload is maxed, because you can't send ACK packets back for the traffic coming down.
This isn't traffic shaping, that's what you use to solve this situation! I'm using pfsense priority queues and Windows QoS tagging for this because I'm stuck on a 4Mb/0.8Mb link and I need to leave crashplan running continuously to get any data uploaded.
erm perhaps im misunderstanding you but no, the download is fine its the upload that sucks. specificaly with uploading to google drive, on any browser. yet the same thing on a different computer on my network and the upload runs 10 to 20 times faster.
its not that the connection is being saturated.
Ah, ok. I guess I read the post the wrong way, I just assumed it was the internet in general that was slow rather than uploading.
Assuming that the speed test is from the machine? Is uploading ok to other places or is it just google drive that is slow? Is is any better if you create a new user account on the machine to rule out browser cache/settings issues?
Hmm, http://www.tomshardware.co.uk/forum/312236-30-beware-asus-network-icontrol-kill-upload-speeds
I'd still blame icontrol, is it uninstalled? And have you tried the standard realtek drivers?
removed network i control thing. still the same.
the drivers in use are ones i got directly from realtek so id like to think there should be no playing about with them.
yes that speed test was done on this machine so atm it specificaly seems that its uploading to google drive that is slow on this machine. ive not noticed this behaviour on anything else. it hapens in multiple browsers and even using the google drive app. thats why im thinking its some traffic shaping thing but ive no clue what could be interfering.
Have you tried with high performance power plan? if only to rule out pci-e power saving settings. Antivirus might also be involved if it's filtering ssl
well im going to assume that its not pcie power saving as its not general connection issues, for example the speedtests upload fine. it seems to be specific services only that are affected.
