I spotted I had HDtune installed on my system and decided to give it a run. Results were fine on my 500GB WD 5000AAKS but on my older Maxtor IDE drive (Maxline III) I got this funny pattern: seems my drive is capped at 30mb/s - I know it can go faster as I remember running it a while back, and no HDD pattern is completely straight. Ignore CPU usage, as I ran the test twice and it came up with a completely different value the next time so I think it's bugged - HD tach shows CPU usage as V. low as well.
I tries HD Tach to see if the problem was the same, it was indeed. Notice burst is also capped at 30mb/s.
I can't say I'm too bothered about this - I was planning on upgrading the Maxtor to another 500GB drive because I'm running out of space, it's a real stretch for me to get both the DVD drive and HDD on the same IDE cable (my god I hate those things) and it's mucking up my neat and tidy case, plus I've heard some horror stories about Maxtor reliability.
The error scan is completely fine in HD Tune and other than "Reallocated Sector Count" being yellow under Health ( I don't know what that means!) but still saying OK under status it's completely fine. It is an old drive though - power on time says 21406 (hours?) and I've had it for many years now (3-4 I think)
Do people think it could be an OS issue or is my HDD slowly dying? It isn't clicking or anything, and I've experienced no corruption of files - in fact I'd never have noticed the problem if it weren't for the benchmarking tools as it's just a storage drive - I don't run anything off of it.
Unless it has something to do with the jumper placements, although I don't see how a wrong jumper would restrict the speed, it would either make it work or not work correct?
