Western Digital Blue SN550 and Gigabyte Thermal Guard
19 Jun 2009
Here is a quick question. I'm fitting a WD Blue SN550 to an Gigabyte X570 Aorus Elite motherboard.
If installing in the top slot, do I just place the Gigabyte Thermal Guard directly over the top of the SN550, i'm presuming there is some thermal pads on the underside of the Thermal Guard.
Second quick question. I presume the top M.2 connection is the best one, and not the bottom slot? I'll be using a single graphics card in the computer.
Many thanks
Top M.2 slot is always primary slot to fill first:
It's connected directly to PCIe lines from CPU and hence it has slightly lower latency than slots connected to chipset.
Thermal pad has plastic film/tape protecting its surface and if you leave it there, that obviously weakens heat conduction.
EsaT,
Thank you, I've never actually installed one of these before, I thought the above but wanted to confirm.
Thanks again
EDIT. Managed to get it installed ok.
