Western Digital Caviar SE16 320GB
messiah khan said:
Its nothing to do with the bios. You need to make sure you have service pack2 installed for Windows. Then go into Control Panel>Administrative tools>Computer management>Disk management and format the unallocated space.
Problem is I already have wndows XP installed :( on the harddrive
is there a way to merge the 2 partitions ofr shall I just format it and set it as an alernating drive?
