The OP is not asking about a GTX 770 and also the GTX 770 is no faster than the HD 7970 anyway.
I would appreciate any input!
Also, yes the 770 is faster than a 7970.
I thought about the 770 but I really like the extra GB of available memory and also since the PS4 and XBone are running AMD games might be a bit more optimised for them which appeals to me. Plus I've had my 5870's for years, and before that a 4870, and my first ever real card was a 9800 pro, so I have a bit of brand loyalty
EDIT: Sorry I really don't mean for this to turn into a 770vs7970 discussion, that wasn't my intention at all, I would just really appreciate input on my best option for 7970 or 7950 if that's better overall.
For what reason do you recommend this? Better price/performance or something?
I have had 6 79's, 2-70's and 4-50's:
7970 WF, ok silent@idle, aggressive when it hits 60c, medium clocker@1150MHz but developed a fault within days-returned.
His Ice-Q 7950, annoying grating noise@idle, not bad on the noise under load, rear venting too-tremendous clocker@1200MHz-returned as I'm anal about noise.
MSI 7970 OC another tremendous clocker@1200MHz+/1850MHz on the memory but died out of the blue-gutted but full refund as they are hard to get now-seriously bad noise levels but it was sat on top of the fantastic AC Extreme.
XFX 7950 seriously cheap@£200 inc Never Settle bundle-Flawed cooler, poor clocker@1100MHz max voltage through Trixx(meant to be voltage locked), it's now getting passed on to a friend.
Another Ice-Q, monster clocker@1250MHz+/1650MHz His iTurbo full core/vram voltage support-this one doesn't have the grating problem-guessing His sorted it out.
MSI TFIII bought the other day, no diode issue, fan works as it should, 1170MHz/1600MHz+(stopped pushing as it doesn't need to go that far could go further on the vram), but AB doesn't apply voltage even though AB reports it as applied, so Trixx to the rescue again, but no vram voltage option-yet(upcoming newer Trixx is supposed to have vram voltage adjustment support).
For gaming@1080p, although the 7970 was fantastic and I was very happy with it, the price difference you pay is only noticeable from your wallets pov.
If it runs on a 70, it runs just as good on a 50 when they are both oc'ed, the only way I would say go 70 is for high res gaming or bench marking-where the little extra oomph(the vram clocks considerably higher due to higher grade chips, so at least there's some justification) will see you good.
So what ones my overall best recommendation?
It can only be this one:
1 x HIS HD 7950 IceQ BOOST 3072MB GDDR5 PCI-Express Graphics Card (H795QC3G2M) with Crysis 3 & Bioshock PC Games £239.99
Contrary to what I wrote, I wasn't happy with the TFIII/Ice-Q combination as it ended up having to rely on two seperate oc tools to apply voltage on both, so I caved in and went with my gut and took delivery yesterday of another Ice-Q and got another brute of a clocker.
The Never Settle bundle was included too and just checked that it's still on the store page:
I can't recommend this card enough and it will probably be back up to £276 tomorrow, if your thinking about one, well stop pondering and get through that checkout as it is a fantastic piece of kit.
That's three Iv'e had now that oc past 1200MHz on the core without adding voltage(the vram needs a touch more to get it going past 1500MHz though), they don't all get to 1200MHz with such ease.![]()
