Just a plug socket unfortunatelyIs that link going to take me to a picture of your butt hole?
One and the same!Just a plug socket unfortunately![]()
Googling suggests India but this is in the uk.
Just need a adapter to make it normal
As has been said it's probably far better to just buy a long extension lead.15 quid is a bit much.
It's in a communal hall for the cleaners. I need to hover my car out but my extension. Lead doesn't fot
I've never seen a domestic hoover rated at 3kW before. 5 amps at 220v is good for a smidge over 1kW, plenty for a Shark upright rated at 750 watts.It's a 5A socket for a light, a hoover (at 13A) would likely pop it.
Buy an extension lead, they are always useful and negate you farting around with a completely useless adapter
