What are these called?
5 Aug 2006
Derbyshire
Hey all.
I detailed the Focus this weekend and noticed a some rusty chips along the rear sill bit that sticks out between the rear passenger door and the rear wheels.
I haggled with Ford down to £100 including VAT to get it sorted.
The man giving the quote showed me a car with these on to prevent the issue returning:
http://i854.photobucket.com/albums/ab108/T55-2009/P170909_095101.jpg
I know they aren't the best looking, but what are they called? Halfords do not sell them.
Despite me ringing up Ford before I bought the car I asked them to check for me and the car does have a DPF after all.
They look adhesive, a quick google brings me to;
Stone Guard Decals
Although I can't find any for a focus, I didn't look all that hard :)
hmm, I'm not sure you'd get it to conform to a right angle, you could possibly do it if you scored one side of the plastic on the contour of the angle.
You can also get a spray on stone-chip product but it would need a lot of work to make it look decent and probably not worth the effort.
Heat it with a hair-dryer, it will stretch to almost any shape :)
