What are your GPU temps?
Caporegime
24 Sep 2008
Essex innit!
With Summer being here, I have noticed how much my GPU temps have gone up. I have gone from never hitting 40c to now hitting 55c and that is under water :eek: If I don't oc, the cards will sit around 47c but as soon as I add a 24/7 oc, boom! 55c.
What temps are you seeing? I am running a pair of Titans.
84C load, that's with the fan limited to 40% maximum in a tiny little ITX case shoved in a corner. So not bad considering :D
i did notice small increase but not a drastic one maybe by 3 ~ 5 c , depends how much gpu % game uses.
in watchdogs with 99 % usage still 68 ~ 70 c .
EVGA 780 Ti Kingpin 28c idle and about 45-50c in games with fanspeed of about 50.
My HD 7970 was touching 85c-89c the other night to re-applied some premium thermal paste. Hit 73c after 10-15 mins of BF3, touching 80c as the highest temp.
Idle beforehand was 50c, now its 40c. Well I say now, I've just sold it :D
Idle around 1-2c above ambient, load is low 40's, though with an oc it creeps up towards 50c. Need to rejig my loop to give everything more radiator space.
Got 2 270x msi on the stock coolers @ 1100/1400 since moving the 2nd card over to 3rd xfire slot they never go above 60 under full load with the fan speed max set at 65% ... Before the top card was going up to 90
Some big variants on temps. I guess case air flow and different cooler types can seriously make a difference. Just shows the importance of keeping our cases dust free (something I should do).
:D
Hmm where do I start..
Six 280x in a cellar on an open bench are around 65 degrees
Two water cooled 7990s mining around 40-45 degrees (two 360 radiators + 4770k on loop)
Five 290s around 70 degrees all mining
Not much of a change really
