Briton said:Thanks for reply. I know that the standard cable can be used but thought VGA or component might give a higher definition picture.
ScarySquirrel said:VGA is thought to give a better picture but more washed out colours.
I use VGA but only because my component connection is used already. I really noticed no difference in quality but the colours were slightly washed out, however this was sorted by changing TV settings and there are now options on the 360 Dashboard to change something which gives better colour via VGA.
It really depends on the TV I think. Just use component if I were you.
Depends what you mean by standard cable. If you have core then you just get a composite cable with it (yellow video plus red/white audio), which you should not use since it's SD only and awful. If you have a premium then you get a combined component/composite cable (red, green and blue video (component), yellow video (composite), red/white audio) and you should definitely be using component and not composite with that lead.Briton said:Thanks for reply. I know that the standard cable can be used but thought VGA or component might give a higher definition picture.
CSA said:Im about to order a SAMSUNG LE32R88BD 32"
but no idea what cables i need to connect my premium 360, will the supllied cables be ok or should i get the VGA cable mentioned in this thread ? or is there another cable i can buy for the hdmi sockets on the tv ?
