What cables do I need with M4 drive?
just a sata cable which will come with your motherboard,usually they include four cables in the mb box
the sata power connector will be joined to your psu just plug it into the ssd,connect the sata cable to the first intel sata3 port
sata2/sata3 cables are identical in performance
try to connect it to a sata 3 port on the mobo for optimal performance and remember to set it in ahci before installing windows :)
ahci enables extra features like native command queing and will give the best read/write figures on an ssd,enable it in the bios before you install windows(beat me to it!!)^^^
