What can i do at home with...
17 Aug 2005
Swindon
Pretty limited space and a set of 10kg weights.
At the mo i do a varied set of exercies like
10/15 pressups
15 - walking woodchop lunges
15 - bumb-bell pull over crunches
Dont know the name of the exercise but flat on back lifting weights up from my side straight arm and back down.
I do some bicep curls at times as well. I think i covered a lot of muscle area with them but i aint too sure tbh.
Anything else people can recommend doing with or without my weights??
I wanna loose a bit of bodyfat ideally
As already said, CV work needed for fat loss really, although you can work up a sweat and raise the heartrate by doing a good circuit using the large muscle groups if you move quickly from one to another and add in a few cv stations eg: skipping or jogging on spot.
I'd add in
Squats
Lunges
Dorsal raises
Ab crunches
Tricep dips off bench/chair
I like to put a CV station between each one to raise heartrate and keep body warm.
