What case to use?
13 Dec 2020
Cambridge
Hi all,
Can someone please help me choosing the best case for my new build? I've been looking around for reviews but didn't really come to a conclusion as the reviews are not very clear.
Budget for a new case: ~ £80
New build include and ATX motherboard, possibly an RTX GPU (if I manage to get one without having to sell a kidney :D)
Haven't decided about cooling but at this point it will probably be air cooling for the CPU
Ideally looking for a case with a temp glass side panel.
Thanks,
proxyc
Fractal Design Meshify or Phanteks P400A. A bit more expensive Lian Li Lancool II Mesh.
Make sure it's a proper airflow case. Solid front panel, no miracle, will limit you.
Bottom fan mounting space is desirable, as could help a lot your GPU.
Thanks for that. I will have that into consideration and try to find some reviews about them
Be quiet 500dx or phanteks p400a
The Be quiet model seemed to be really interesting, as well as the P400A mentioned here were the one that I've shortlisted, but they are both above my budget at the moment.
Was well surprised with the reviewed about the Fractal Design Meshify as well, really nice case
Thanks for your help guys.
What's the P400A like for dust? I have a Define S that lets litterally NO dust in at all thanks to it's filters.
I need to buy another case for my son, so interested if others are any better?
From what I could gather from the reviews it seems to have very decent filters to block the dust from coming in to the case. Have seen some review where was mentioned about the double thickness filters, but I not sure where I've seen it. Will post it here if I manage to find it
That would be great, thanks.
A I've seen is that the front mesh is the only filter
Define S lets little dust in because its airflow isn't that great. The P400A has great airflow and the front mesh is effective but not as good as the much finer mesh in a DefineS. You can have great airflow or great dustfilters but you can't have both.
Cheers. I thought as much. My room suffers badly from dust, as I have my Rad as a front intake, I think the define S with high pressure fans is probably the best option still.
If it's any help, I did a mod on my Define S that cut out all but a one inch surround on the front panel and then covered it with mesh bought for just a few quid.
I had seen this type of mod - Did it lower the temps much?
Do you use an AIO or cpu cooler?
Also, where did you buy the mesh from??
This has a 60mm thick 360mm rad behind it for a full custom loop.
The mesh came from auction and is "DIY Computer Mesh PC PVC Case Fan Cooler Dust Filter Network Net Dustproof Cover". I also put strips of mesh around the sides (on the inside) of the cover and the bottom which allowed me to remove the inside dust filter as well.
Two things made me do it, one was of course airflow. The loop temps were no problem and TBH, I doubt it made much difference as the rad easily cools the low power components. Mainly it was aesthetics. I'd bought some fancy fans and the solid front made them invisible :p but I do think it's a worthwhile mod. Cost under a tenner to do the whole thing.
