Hi,
I'm currently after a decent looking case (preferably with clear side window
)for my new dual core gaming rig. Needs to have decent airflow, room for plenty of drives/8800GTS etc
Ive had a look on overclockers and like the Look of the Antec 900, although not sure how quiet it will be with the massive top fan and 2 front fans etc.
any ideas/advice, or others products you can recommend? Got about £90 max to spend on the case.
)for my new dual core gaming rig. Needs to have decent airflow, room for plenty of drives/8800GTS etcIve had a look on overclockers and like the Look of the Antec 900, although not sure how quiet it will be with the massive top fan and 2 front fans etc.
