what chain removal tool?
28 Sep 2008
Britain
I know I know. I could just go and buy one but its been a while since I removed a chain on a bike and I have Sram stuff. Is there anything I should look out for? Like, the pin needs to be renewed or put in a special way when re-installing?
Whether you're using a SRAM or Shimano chain just use the appropriate SRAM powerlink (9 or 8 speed) to reconnect the chain rather than a pin. Buying a new Shimano chain it will come with a pin, I think SRAM come with a powerlink. On my MTB's I always use Shimano chains with a SRAM powerlink, just personal preference on using Shimano chains.
