- 7 Jan 2009
Hey guys,
I have a second NVME drive which i want to make use of,However i cannot install it into the second NVME slot on my motherboard because that then disabled the 4th PCI-e slot on my motherboard which i need!
So i was looking to maybe get an external solution,But im so confused to which i should look at getting for maximum speeds,USB-C,Usb 3.1 ive read through posts and my mind is boggled lol.
My motherboard has the following ports. (i see it has an internal one too)
Appreciate the help guys
ASMedia® USB 3.1 Gen 2 Controller:
CPU:
- 1 x USB Type-C™ port on the back panel, with USB 3.1 Gen 2 support
- 1 x USB 3.1 Gen 2 Type-A port (red) on the back panel
Chipset:
- 4 x USB 3.1 Gen 1 ports on the back panel
- 1 x USB Type-C™ port with USB 3.1 Gen 2 support, available through the internal USB header
- 4 x USB 3.1 Gen 1 ports available through the internal USB headers
- 8 x USB 2.0/1.1 ports (4 ports on the back panel, 4 ports available through the internal USB headers)
