Hello everyone,
I'm planning to setup a new PC build and I picked up the Ryzen 5 2600 and am pairing it with the B450m Aorus Elite from Gigabyte. The last part I need is the RAM and I'm planning to use the kit by G.Skill; "F4-3200C16D-32GVK". However, I am unsure of the die this particular RAM kit uses. I believe it was confirmed 3 years ago that it used Hynix M-dies, which in the present after BIOS stability updates seem to work well with the Pinnacle Ridge cpus. However, I've seen some recent reviews that they apparently ship with cheap Samsung B-die now and I'm wondering what the compatibility of this cheap B-die is with a Pinnacle Ridge cpu. It's fine If I can't get it to run XMP, I'm just hoping for a 2933mhz speed on the RAM.
PS: Getting RAM from the QVL list of my motherboard is out of the question, the 32GB RAM kits are either all too expensive since they're in 4 modules, or just too low of a speed. (Plus the fact that my time is running out to build this PC, I have to buy stuff from my local store, and this kit seems to be the only one that fits my criteria). I also found some Corsair 32gb kits from another local store; CMK32GX4M2B3200C16, however they are v4.32 and I've heard those clock horribly with Pinnacle Ridge CPUS).
Thanks for reading or replying, I appreciate it.
Update 31/12/2020: Built the PC today, ended up getting the G.skill F4-3200C16D-32GVK. It didn't run at 3200mhz XMP, but did fine when I enabled XMP and changed the multiplier to get a frequency of 2933mhz. Running it through Thaipoon burner, it does indeed seem that G.skill have changed the dies they use from 3 years ago, from Hynix M-die to cheap Samsung B-die (K4A8G085WB-BCPB), hence why I probably couldn't run it at 3200mhz. Thanks everyone for the replies.
