What DisplayPort cable
16 Feb 2019
Looking to buy good Display Port cable.
80Gbps 3850 x 2160 @165Hz
Using with AMD Radeon RX 7800 XT and Alienware 27" 4K Dual-Resolution Gaming Monitor - AW2725QF
Searches bring up brands I'm not familiar with
UGreen
Sniokco
Silkland
Club3D
Stouchi
LDLrui
Any of these better for DP cables ? (or ones to avoid)
you happy with uGreen and Silkland ... never bought either of those makes.
Previoulsy been whatever came with monitor or an 'amazon basics', having built new PC & just ordered a new monitor makes sense to have a decent cabel
Yeah both have been excellent.
I'd expect a monitor to come with at least 1.it will be fine and I'd only replace it if it wasn't long enough.
I tend to use Kenable for all my cable needs. UK firm, never had a bad one.
I just bought a Kenable 2M braided DP 8K 120Hz/4K 240Hz, for around £8 posted on their store on a certain auction site. Can't go wrong.
Also used them for HDMI 2.1 cables in the past.
They're all 'certified' cables, and seem to work perfectly :)
I've used Kenable & UGreen . I believe Silkland were one of the first 80gbps cables on the certified list. I was going to buy one for my 240Hz 4K monitor but because it uses DSC any decent cable has worked.
I'd normally use Kenable too, but I needed a 20Gbps USB 3.2 Gen2x2 extension cable and they didn't seem to have any. So had to use the rainforest.
I've got a couple ugreen cables and adapters. They seem fine for what they do
tbh though I've never bothered with brand when buying cables, I just buy what is the cheapest and the only time this has ever caused me trouble is when I bought a cheap 20 meter HDMI 2.1 cable
I'm a believer that in most cases, expensive cables are a scam
I swapped out my bundled DP cable with one from UGREEN after my bundled one kept flaking out every time I touched the monitor and it works great.
