If you aren't technically minded use logmein.
I'm technically minded, so I went a different way.
Install Cygwin and OpenSSHD.
(http://www.petri.co.il/setup-ssh-server-vista.htm)
Setup Dynamic Dns
(http://www.dyndns.com/)
Forward port 22 from your router to your desktop
Make sure RDP is running on your desktop.
From remote machine use:
ssh -L 13386:localhost:3386 [email protected]
Then open Remote Desktop & connect to localhost:13389 and connect to your desktop over an encrypted tunnel.
Note, you can significantly improve the security of your connection by using Public Key authentication, see http://sial.org/howto/openssh/publickey-auth/
My ISP gives me a static IP address, so I don't bother with DynDNS and have a real DNS entry.
But for most people, logmein is a simpler solution![]()
Thanks to everyone for the advice.
Seeing as I like to get my hands grubby I will give the following a go. I would much prefer to actually remote desktop via a VPN rather than a browser.
I understand that using Logmein is easier but I haven't really learned anything that way. Looking below I doubt I will get it right first try and if I do it will have just been pure luck.
But hey, that is half the fun.
Cheers
A lot of companies will have a firewall however which will stop remote desktop connections through the proxy server so Logmein may be your only option, unless that site is blocked too!
Yeah, you don't really want to cut your teeth trying to access a corporate network. You might end up tearing your hair out trying to get something to work that is being filtered out.
Setup Dynamic Dns
ssh -L 13389:localhost:3389 [email protected]
