- 14 Jul 2005
- Birmingham
Hi all,
Simple question hopefully, just want to make sure I buy the right thing.
I have a motherboard with only one 4 pin RGB header. Nothing is connected to it.
I bought some fans which use the newer 3 pin connectors.
What do I need to buy to connect it up, either a converter or a separate controller (and if I buy a separate controller where does this get connected to)?
Thanks
Thanks
