- 11 Jul 2010
- ENgland, Oxford
What do you have to do after building the PC, what do you have to do in the bios, and what do you have to change, E.T.C
Usually select BOOT PRIORITY and then the DVD Drive, so you can install the OS. Then once its done, select the HDD the OS is on from that menu![]()
Overclocking is dealt in greater detail in the overclocking section of these forums. Sorry to pitch the reply at such a low level but I'm not trying to insult you. We all help each other here as much as possible.![]()
Thanks for the HELP! i just want to know what to do after i will complete my first build, and also i would like to do some overclocking i will have the gigabyte UD3r board, i want to overclock the intel core i7 930 to 4GHz with a cosair A70 and i should ahieve this with ease, but i want to overclock after operating system has installed and maybe give my computer couple of days to settle in, for overclocking shall i download software or do it in the bios, and i am useless at overclocking never done it before.
I just want everything up and running. Then think about overclocking.
i start planning to build another.
