Hi,
So i've been planning this upgrade for few months now and finally have enough budget to go ahead with it, just wanted your opinion on my choices (there are likely to be better options)
My current spec is:
P8H61-MX Asus Motherboard
8GB DDR3 RAM
i5-3450 @ 3.10GHz (not OC'd, obviously)
MSi AMD R9 280x 3GB
Antec VP550P 550W PSU
CM Stryker Full Sized Case
My upgrade choices:
https://www.overclockers.co.uk/showproduct.php?prodid=GX-287-MS
https://www.overclockers.co.uk/showproduct.php?prodid=CP-548-IN
https://www.overclockers.co.uk/showproduct.php?prodid=MB-297-MS
https://www.overclockers.co.uk/showproduct.php?prodid=HD-183-SA
https://www.overclockers.co.uk/showproduct.php?prodid=CA-195-CS
https://www.overclockers.co.uk/showproduct.php?prodid=MY-408-CS
The reason I'm going for a larger PSU is because my end game is to SLI that 980Ti, although looking at it now, I could probably get a cheaper one. I'm not very knowledgeable about the actual RAM so do you guys think the option I've gone for is ok? In terms of all of it, any better choices I could go with?
Thanks for all the input
P.S. Sorry - i tried to link all this using the chrome extension add-in but it doesn't seem to show up on my address bar when I'm actually viewing my basket..
My current spec is:
8GB DDR3 RAM
MSi AMD R9 280x 3GB
My upgrade choices:
