- 12 Dec 2002
My car RR'd today what do you think of these graphs, something not right??
Torque and power should cross at 5252rpm (mathmatical constant)
somethings not right...
Torque and power should cross at 5252rpm (mathmatical constant) - Yours doesn't, looks to do so about 4100rpm. Suggests to me that the RR is not set up properly.
Also runs out of puff fairly early - is the car stock?
They're plotted on completely different axes, you can make them cross wherever you want under those circumstances,
hmm I think I will remove the map to be safe, could the actuator be set too weak? the general advise on the vxr forum is slacken it off once the precat is removed and allow the ecu to dealwith theboost although this sounds crazy.
Are the dots the samples?
I think the line plotting function is in a bit of a funky mood if this is the case.
