Permabanned
- 28 Dec 2009
- london
Only 14.4 volts.
And useless for masonry.
You're probably pushing it with wood You may be able to get through some very thin plywood with that
I probably should have asked before I purchased it. But i just went out and purchased this. Its all they had at robert dyas near work for low price and was not sure what to get.
At this point i just want to install a door lock an internal door and put together a bed (screw driver) as well as potentially drill some holes in my crappy walls (which i don't think are real brick)
I can always take it back. I just paid £60 including a £20 bit set. Should i take it back, have not opened it yet, and what would you suggest for same price? I need the 16mm drill bit.
Are you joking or serious?
If its that rubbish then ill take it back. Any suggestions from this list
http://www.robertdyas.co.uk/?attributes=773,777&sort_order=PRICE DESCENDING
