Hi there, hope someone can help
I want to upgrade my raid array. I have a 3ware 9650-12ml raid controller running 12 non-enterprise 500GB hard drives in a single raid6 array. now at the time i built this array i had no idea what i was doing (clearly!!)... and i still dont. However, i read recently about unrecoverable read errors which made me feel uncomfortable as the way i understand it is when a drive fails in my array and i go to rebuild, theres a very high chance that i will hit a URE.
anyway, i want to buy new drives and build something with a large capacity and a high level of fault tolerance (including a low probability of failure to rebuild in the event of losing a drive).
can someone give me advice on what drives I should buy and how i should configure them? should i setup blocks of 4*3TB in raid6 or what? I want to use 3TB hard drives so i can get the maximum amount of disk space out of whatever array(s) i build (4TB is too expensive). How should i configure these 3TB drives? lets presume i will eventually be running 12*3TB but initially i can only afford 5.
any advice would be appreciated.
humate
humate
