What Drives to get, help please..
8 Nov 2002
Parson Drove near Wisbech
I would like to upgrade my hard drives, basically to get new but also so they are faster, I would like 500gb drives to run in raid, Please advise me as to what I need, the size's of the drives can be up to 1TB.
Also advise as to how raid really works in our systems please, any help appreciated, Thank You all for looking..;)
Which make drives is down to you - they are all pretty reliable and mostly the same speed, until you start getting into the velociraptor type area, but then you'll easily notice it in the price difference!
500GB is normally about 40-45 per drive, 1 TB is 65-70 per drive.
I think your motherboard supports RAID 0,1,5 and 0+1 out of the box. You can find more info on them on wikipedia but here is a summary.
Raid 0: "joins" the drives into one big drive. You keep full capacity of the drives (i.e. 2 1TB drives = 2 TB), read access is technically doubled, write access up to doubled as well. However, this has no reliability - if ONE drive fails you lose ALL the data. You can RAID 0 any number of drives together, 2 or more.
Raid 1: "mirrors" the drives. You get capacity of one drive (i.e. 2 1TB drives = 1 TB). Read access is doubled, write access is about the same as 1 drive. This has reliability though, you can lose all but one drive and not lose any data. You can RAID 1 any number of drives together, 2 or more (but remember that doesn't give you greater capacity, just more reliability and read access)
Raid 5: complicated to explain, but is somewhere between 0 and 1. Takes a minimum of 3 drives. You have the capacity of all drives minus 1. (ie, 3 1TB drives = 2TB, 4 1TB drives = 3TB). Read and write access about the same as raid 0. However, it can tolerate losing ONE drive and one drive only.
Raid 0+1: Raid 0 and 1 together. Takes 4 drives minimum, can support up to 2 drives failing. Gives massive read speed and good write speed. You get the capacity of 2 drives (i.e. 4 1TB drives = 2 TB capacity). Best all round performance and reliability, but takes a lot of drives.
What you go for depends on your backup strategy (if any) and how much money you have burning a hole in your pocket. Consider also having a small capacity SSD (128G, say) for your OS and programs, and 1 TB or more behind it on regular drives for data files.
Good luck!
If you don't know what RAID is, how do you know you want it?
Hearing how people have had there read and write speed increased and also more reliabillity, Also now having done some research my self I may go the way of a 128gb ssd and poss a 1.5 tb as back up, lots more speed from ssd and lots of back up with the other.
Maybe reading befor posting is alsothe way to go.:p
Hehe. Sounds like a good plan, but make sure your backup has backup.. hard drives can fail without warning.
And generally, when most people talk about performance RAID, they are talking about RAID0 which increases transfer performance while decreasing reliability.
I thought what I would do is get the SSD for the os and programs and use the 1.5 for all backup and music , photo's and that kind of thing but then also I have an external drive which I will use to make ghost copies of each drive, if 1 was to go down I still have the data on the ghost drive, then I could pack away the external drive untill I need to renew my back ups..;)
