So I've just built a new rig. Had it working did a few minutes of Aida64 CPU stress temps <80 Ran Unigine superposition No issues. Playing warzone for a hour maybe 2 and suddenly computer switches off. Went over pushed the power and the lights (CPU cooler and front fans) literally flashed on/off. Then nothing. Switched the psu off/on same again.
Pulled the cable for a few seconds put it back in had the GPU EZ light on on the MOBO, but everything seemed on (I think the light on the radeon logo was on and fans were turning). No display on my monitor. Turned off tried again, same thing. Got the pc out of it's place and had a look on the floor now I have nothing but two clicks from the PSU. Pulled all sata cables out and still click click. Pulled GPU out (reverse breadboarding style) Everything now runs (haven't checked to see if it displays as my monitor is plugged in via DP not HDMI but can do this if we think I need to) Tried again with GPU, click click. Got old gtx970 out everything seems to run fine it boots to windows anyway.
So i think its an RMA but is there something else you think i should try first?
All help appreciated
PC:
MSI x570 A-Pro
5800x
rx6800 msi reference
NVME
1 x noctua 120mm and 1 x 240mm case fan
2 x 120mm Lian Li Lanccol 2 mesh case fans running
Deep cool CPU cooler
Run with a corsair TX850M PSU
Additional drives that were removed
2 x2.5 SSD
2x3.5 HDD
LED Supply for the Fans
PC:
MSI x570 A-Pro
5800x
NVME
2 x2.5 SSD
2x3.5 HDD
