Thanks Mikey will have another look see if that is a common problem although it hadn't come up in everything i have looked at so far but always good to hear about something if only to eliminate it.
I'm probably going to check everything over (prob after 7th August due to my wedding) and go from there.
I was looking at the sound deadening stuff and contemplating replacing the Noctua fans at some point and adding extra fans, but at v low speed in the top.
I'm not water cooling and don't intend to.
I have 5 drives in the case which I don't think helps the vibrations etc. So long term, which defeats why I got this case I'll be moving them out into a NAS etc.
I had a similar issue on my 800d after i changed the 140mm fan to sharkoon ones massive buzzing it was setting up a bad vibration on the shelf between the two compartments buzzing against the door, I would check the RPM's of that fan, i slowed mine down with the controller till the buzzing stopped and it was all good, I am going to put it on rubber mounts which should stop it entirely.
So if the buzzing is between the compartment floor and the door maybe some of that stick on rubber draft proofing stuff might do the trick although shouldn't have too but there isn't any other case that matches this for features that i want.
