Hi guys
sorry i'm a little new to this
I'm running fx-8350 5ghz on 8 cores and a hd7970 1.1ghz/1.5ghz. 16gb ddr3 1600.
I know it's no mining rig, just my desktop, but I might only use it 2-3 hours a day with all the time i'm at work at the moment, the rest of the time it could be folding.
I've just started doing F@H and thought i was doing ok with 20k ppd but i've read some people are getting way more, even with similar stuff. Someone told me it's F@H that doesn't work well with amd stuff, so my question is which project will best use my hardware?
i dont have a bitcoin wallet or anything i'm just doing this to help out. any advice would be great! thanks!
Whenever you feel the need just go to your selected projects account page and search for OCUK or Overclockers in the team section and you should find the team listed then select it to join.
