yesWill I definitely need to update the bios on a B450 irrespective of what I get in the post?
depends on which brand you get.is it a pretty simple process?
MSI B450 Tomahawk & Carbon BIOS can be pre-flashed via USB without having to install a Zen 1 CPU first
Move up a platform, waste of money buying a 4790k now, you didn't mention a budget either, your 1070 should last you a bit longer at 1440p.
Hi all,
Just off the back of this, I've now settled on the below;
Mobo - B450 (Tomahawk)
CPU - Ryzen 5 3600
DDR - Team Group Delta RGB 32ghz
Will I get away with keeping my 1070 for awhile yet, or will this hold back the rest of the build?
1070 is fine for 1440p 60hz high/ultra
Move up a platform, waste of money buying a 4790k now, you didn't mention a budget either, your 1070 should last you a bit longer at 1440p. Maybe something like this? Shouldn't be too budget intrusive; My basket at Overclockers UK:
Why 32gbs of ram out of interest?
32GHz = 3200MHz - so probably only 16GbDDR - Team Group Delta RGB 32ghz
ah yea my bad I just glanced over it32GHz = 3200MHz - so probably only 16Gb
32ghz actually = 32000mhz32GHz = 3200MHz - so probably only 16Gb
32ghz actually = 32000mhz![]()
#justsayingya bugger
yeah. not clear enough(he may yet mean 32 gb)
True - needed clarifying on these forums too.#justsaying
