- 26 May 2008
After seeing another thread where someone was having issues with both HDMI connected, I was curious as to what current GPU's can actually output 4k at 120hz over two HDMI outputs?
I was looking at getting either a Sapphire Pulse+ 9070XT or an Nvidia 5070ti around £700 or thereabouts.
From what I have read DisplayPort is limited to 2m lengths passive, whereas with HDMI we can run passive up to 5m and 10m with active HDMI high speed. As an example, if my sitting room PC location was connected to the TV, it's either 3m or 5m, up to 10m if using a projector too. So I would be interested in having the option of two Display Port and Two HDMI possibly. Even with the main PC living upstairs it is often connected to a TV again 5m away while also running a monitor, but currenty limited to 1080 output to a 1080p monitor and 4k TV.
My main PC upstairs usually sits on a HiFi rack in the corner, currently under the desk due to moving things around and too much tension having been on cables. Downstairs the audio racks are currently 8m away from the TV, though that may change, the wife isnt too keen on the racks and a visible PC, so the option of various long cable configurations may be of benefit.
It should not be a deal breaker, but reading about another guys problems with dual HDMI output has sort of put me off AMD somewhat, only to find I can't see any 5070ti with dual HDMI as an option anyway?
