- 6 Feb 2010
The problem is the cost of those high-end all-in-one water coolers..air cooler could often achieve the same cooling capability at 1/2 or 2/3 of the cost.i also have an q9550, to oc it you need a good cpu cooler, im using a phantek dual rad air cpu cooler and it a monster at cooling but you need a big case for it. if you what excellent cooling but don't have case for big dual rad air coolers or full watercooling setup. then i suggest something like a h60, h80 or h100 closed loop watercooling units. one of them will let you oc you cpu to 3.8-4.0ghz. as for graphic card the rev2 of the msi 7950 tfIII is an excellent buy and will do you well. i've recently bought the HIS IceQ 7950 BOOST when it was on sale for £224 few days ago and runs tomb raider on high @1920x1080 on a 42" screen fine. the only problem you mght fine is that your psu won't let you have a stable oc and run the 7950 as i suppect you might have rippying happen even with the 600w psu.
Also for the kind of games that OP is playing (World of Tanks and PS2), plus on a 120Hz monitor, he would be better off trying to find a cheap 7850 2GB and spend the money saved plus the money on selling his current CPU bundles toward upgrade to a i5. Those games are extremely CPU dependent, and to be frank...even on a overclocked Q9550, the 7950 would most probably not offer better frame rate than a 7850...
