Hi, i have a basic dell dimension 2400 which is fine for what i use (surfin net, playing music etc) but now the 80gb hd is full and i cannot delete anything else so time to buy a 2nd hard drive for all my junk. I am ideally looking for around the 150-250gb mark. I have no idea what makes are better than others and i take it that an IDE setup would need to be used for my system?
Also because its a dell pc, it comes with a system restore disc. If i do install a 2nd harddrive and when the time comes to restore the system, will having an additional hard drive cause any problems? Will i lose any info on the 2nd hard drive or does it just wipe the C:/ drive clean and start afresh when inserting the system restore cd?
Thanks for reading
Dean
Thanks for reading
Dean
