Theres to many to chose from!!!
The motherboard im buying is the EVGA Nforce 680i one so thats SATA drives,
Is it better to have two drives and run them as one or just have one really fast drive like this one for example:
http://www.overclockers.co.uk/showproduct.php?prodid=HD-073-WD
There a bit expensive, with the cost of one of those 150gb drives i could buy two 250gb drives and still be less costing!!!
bit confused...
bit confused...
I suggest you buy more RAM.
