Hi all! Ive read the sticky notes but I'm still a little confused. Im planning a big upgrade, prob early next year. Mobo, CPU, Power supply, RAM and hard drives (will run out of funds, so not the GPU yet). But im still not sure RE hard drives. I have HDD at the moment, windows on a 256gb hdd and steam for games on a 6TB hdd.
If i want to see an appreciable uptick in loading times for say Warhammer 3, which is woefully slow to load games and load pre/post battles, should i be looking at M.2 or NVME? Is one better than the other?
As an example (and i know by the time i buy something better may be along!) im looking at something like this for a mobo:
www.overclockers.co.uk
The specs RE drives say this:
Does this mean it can take at least 2 M.2 drives (i will reuse the HDD as extra back ups, but ill want windows and games on new ones); and as NVME isnt mentioned, it wont take those?
Edit: looks like these attach direct to the mobo rather than by a cable, so does that mean you need to ensure the case will accommodate either type?
thanks!
Asus ROG Maximus Z690 Hero EVA Limited Edition - Intel Z690 LGA 1700 DDR5 ATX Motherboard
Order Asus ROG Maximus Z690 Hero EVA Limited Edition - Intel Z690 LGA 1700 DDR5 ATX Motherboard now online and benefit from fast delivery.
Total supports 5 x M.2 slots and 6 x SATA 6Gb/s ports Intel® 12th Gen Processors M.2_1 slot (Key M), type 2242/2260/2280/22110 - Intel® 12th Gen processors support PCIe 4.0 x4 mode Hyper M.2_1 slot (Key M) via ROG Hyper M.2 card, type 2242/2260/2280/22110 - Intel® 12th Gen processors support PCIe 5.0 x4 mode Intel® Z690 Chipset M.2_2 slot (Key M), type 2242/2260/2280 (supports PCIe 3.0 x4 mode) M.2_3 slot (Key M), type 2242/2260/2280 (supports PCIe 4.0 x4 & SATA modes) Hyper M.2_1 & slot (Key M) via ROG Hyper M.2 card, type 2242/2260/2280/22110 (suppports PCIe 4.0 x4 mode) Hyper M.2_2 slot (Key M) via ROG Hyper M.2 card, type 2242/2260/2280/22110 (suppports PCIe 4.0 x4 mode) 6 x SATA 6Gb/s ports |
thanks!
