What in ear phones do people use?
ajf
ajf
30 Oct 2006
Worcestershire, UK
After a new set of in ear phones to work with iPhone and probably iPad and Mac as well.
Is there anything that will be as easy to move between devices than AirPods?
I was tempted by the Sony WF1000XM4 as an alternative and they are cheaper than the AirPods Pro.
Any thoughts or other suggestions?
I listen to a very wide range of music types but not bothered about things like exercise features etc, just the sound quality.
Soundcore Liberty 4's & they on offer atm £111, absolutely love mine & you can switch between 2 devices as well, and if you don't like them you can always send them back no trouble.
  • Like
Reactions: ajf
AirPod Pro 2, wouldn't be without them.
This.
I had the old Sony WF1000XM3 but after a few months I swapped them for the Airpod Pro Gen1. It's not that the Sony's are bad but the APP work so much better with apple devices, the transparency mode was better, more comfortable for long use and I liked the smaller case.
I gave my partner the Sonys but have since bought us both a pair of the 2nd generation airpod pros.
Worth every penny and as soon as my Gen1 Pros developed an issue (through fault of myself and years of daily use) I got the Gen2 without hesitation.
airpods pro 1 currently, been working great and have no reason to upgrade or change for my in ear pair.
For overheads I currently dont have one, but im struggling to pick between the xm5's for sony or the airpods max. Im in no rush to get a pair of overheads so im most likely just going to wait for the airpods max 2 or the xm6 and base off of reviews
I don't get on with the AirPods Pro so I use the standard AirPods, third generation. They fit my ears perfectly and I don't need or want noise reduction in this style of earphones.
  • Like
Reactions: LiE
Another vote for AirPod Pro 2. Since they released the original Pro's I've not looked at anything else.
Thanks everyone.
I will look at the alternatives suggested but think I may play it safe and go with the Airpods.
These are actually to replace over heads (Sony WM1000XM3) as I just can’t get on with them. Find they put pressure on my glasses and I end up constantly moving them around.
I doth protest. This thread promised in-ear phones.
Another one for AirPod Pro 2. Sound quality is nothing short of amazing for the form factor. The ANC can be very useful also.
@Devrij
had a bad accident with my Between Pro last week, on a hotel balcony and the box fell onto the pavement 4 floors below.
I contacted Status Audio to see if there was anything they could do because my right earphone wouldn't work.
I get an email saying we'll knock you 50% off which I was amazed at.
I asked if they would do the same deal on the Between 3ANC and he came back with a 'yes'.
Just ordered them :)
