what is Alphacool Top all about on pump ??
Permabanned
3 Jan 2008
Hi looking to buy Laing DDC2 12V 18w pump and notice some places that sell it offer Alphacool Top.
How do I no if I need a Alphacool Top ?
bit confused :confused:
The standard Laing pump top has a restrictive inlet that hampers pump performance. Aftermarket tops basically fix it and improve performance, the different tops all perform much the same.
So for better performace I should get Alphacool tops ?
All so guys Do I need to buy and add fans to a ThermoChill PA120.3 or does it all ready have them ?, from pictures it doesn't really show any fans at all.
Personally I would pay the extra for a separate top and as PinkFloyd says it also lets you use your choice of barbs.
You'll need to buy fans for the radiator.
YATE LOON 120mm fans a popular choice ?
and last daft ? what are barbs?
barbs plug directly in to the pump and you then add the tubing to the barb.?
If I've got space I use 1/2" barbs with 7/16" Masterkleer tubing, if space is tight I use 10/8 compression fittings and Asetek Waterchill 10/8 tubing.
Most thread sizes in blocks etc are G1/4 screw thread, with the exception of Thermochill PA radiators that use 3/8" BSPP thread.
