- 18 Mar 2008
2 samsung f1 drives or 2 wd raptors 150. which setup is faster in raid 0?
so, the samsungs would be faster?The Raptors since the seek time should be lower. However the Samsungs offer a lot more than speed.
kk, thanks a lot. ill probably get the raptors thenno, the raptors because the seek time is lower. depends what are going to use them for. sustained transfer the samsungs should be faster, but the seek time on the raptors would be lower.
For the money the Samsungs would be a MUCH better deal.kk, thanks a lot. ill probably get the raptors then
good point, i thought something was wrong when the raptors r £120 a go.For the money the Samsungs would be a MUCH better deal.
thnks for the info, gonna get samsung drivesI don't think you'd really benefit with the raptors considering how much they cost per GB. Depends on your storage requirements and budget really, if you don't need that much space and you have cash spare then go for the raptors but if not then get Sammy F1's or the new WD 620 GB AAKS drives.
I misread that as "...new 250GB maxtors which runs DEAD."
heh
Anyway, the reason for my posting - I currently have a raptor 74GB which I bought several years ago. Are the ones available now the same, and can I/is it sensible to buy one more and put them in RAID 0?
Cheers in advance!
Roo
