What is the best monitor for my mid range setup 1080p or 2440p
31 Mar 2021
Hi. I'm looking for advice on the best gaming monitor to buy for the following mid-level setup
Motherboard MSI B450 GAMING PRO CARBON MAX WIFI
CPU AMD Ryzen 5 3600X
GPU Nvidia GTX 1660S
RAM Corsair CMW16GX4M2Z3600C18 2x8GB
I'm playing games like GTA V, Witcher 3, Cyberpunk, and Half-Life Alyx on VR (not sure if the monitor affects this or not)
Am I better off with 1080p at 240 +hz, or could I run 1440p at 165hz. I don't game competitively and often play at night with the lights off after work, so I'm also not sure if a VA panel is worth thinking about. Also at present, I have a 27" monitor but have seen people recommending 25" at 1080p.
I've been considering an
ACER Predator XB273X or a
ASUS TUF VG279QM
are these good options or does anyone have any better suggestions up to £400.
Any help or advice will be much appreciated.
Depends on whether you ever plan on updooting that GPU in the next year.
£400 will defiantly buy you more than the GPU can handle. By that logic you might be better off waiting until you can find a new GPU until you upgrade the monitor. A 1660S is able to drive 1080p at around 70 - 110 hertz and 1440p at 30-80 hertz, so it might not be worthwhile doing this at the moment.
I'd probably look into something in the 1440p 144-165 herz range with that kind of money, maybe the: Acer Nitro VG271U, VG270U or XB273UGS if you can find it on offer.
That said I'm personally convinced that above 144 herz is largely pointless, which you may disagree with.
£400 will defiantly buy you more than the GPU can handle. By that logic you might be better off waiting until you can find a new GPU until you upgrade the monitor. A 1660S is able to drive 1080p at around 70 - 110 hertz, so it might not be worthwhile doing this at the moment.
Thanks for the reply cooler, after speaking to a couple of people I have decided to opt for a 2440p and then possibly update the gpu once they appear again. I'm looking at the Razer Raptor 27 as they look sooo nice.
Does look like a cool piece of kit for sure, something along those lines is my preference too.
I personally use the Acer Predator X34P ultrawide and a VG271U. My 1070 is completely incapable of driving either of them though (a 1070 is around or maybe a little better than a 1660S). Definably recommend upgrading the GPU first unless you just need more screen space for productivity and plan on going for the GPU later.
I'd check out some benchmarks if I were you.
Neither 1080p at 240fps of 1440p at 165fps are realistic on a 1660 super.
The only good thing about upgrading the monitor first, is that you will notice the difference when you upgrade GPU at a later date.
You don't need more than 144HZ @ 1440p (IPS) which is pretty much the sweet spot for mid-range gaming, the more you have to spend beyond that, isn't worth the improvements you'll get. That said, you need to have the card to power it.
Stick with what you have waint until next year when things may come back to normal for GPU's and have a look at upgrading then. Now is not the time to be upgrading.
