It looks like that board doesn't support SATA drives which is a bit of a pain because IDE is on the way out - Intel is no longer putting IDE controllers into it's southbridge chipsets. That means you could get stuck with a drive that you might not be able to use in a future upgrade.
The future proof solution would be to go with a decent SATA drive and, as mentioned above, either a SATA to IDE converter or a PCI SATA card although a decent bootable card could set you back another £30-40. Alternatively go with an IDE drive (there's no real speed difference) and deal with it when it comes to upgrade time. If you end up with a board with no IDE sockets then there's always the external USB caddy option.
