Just over 2yr old 2.16ghz MBP..
battery lasts 10 minutes .. if that now
Charge Information:
Charge remaining (mAh): 844
Fully charged: No
Charging: Yes
Full charge capacity (mAh): 844
Health Information:
Cycle count: 261
Condition: Check Battery
Battery Installed: Yes
Amperage (mA): 24
Voltage (mV): 12640
Did you get 3yr apple care with it? if so that would mean a new battery for free?
11 Month 2.4GHz MBP with 9600M GT
Charge Information:
Charge remaining (mAh): 4162
Fully charged: No
Charging: Yes
Full charge capacity (mAh): 4205
Health Information:
Cycle count: 281
Condition: Normal
Amperage (mA): 247
Voltage (mV): 12580
Battery Lifespan
For Apple notebooks with removable batteries — such as previous generation MacBook and MacBook Pro computers — a properly maintained battery is designed to retain up to 80% of its original capacity at 300 full charge and discharge cycles. You may choose to replace your battery when it no longer holds sufficient charge to meet your needs.
The built-in battery of the MacBook Air is designed to retain up to 80% of its original capacity at up to 750 full charge and discharge cycles.
The built-in battery in the new 13-, 15-, and 17-inch MacBook Pro is designed to retain up to 80% of its original capacity at up to 1000 full charge and discharge cycles.
Mac Laptop Maximum Capacity Capacity at 80%
MacBook 5020 mAh 4016 mAh
MacBook Pro 15" 5500 mAh 4400 mAh
MacBook Pro 17" 6400 mAh? 5120 mAh?
