Hello all.
Well having bought an xbox 360 im now looking towards buying a HDTV. However, my room is quite small and thats where i have my pc etc. The screen should be able to:
Play normal tv.. from an aerial.
Play xbox 360.. in HD.. through whatever i can
Play computer.. through whatever i can.. which i imagine is only VGA
It will be a multipurpose screen as you can see, because i am currently using a 19" TFT and for xbox its just naff, letter boxing is annoying me and the resolution problems with PGR3 irritates beyond belief. So as far as i know, i could replace my TFT and normal tele with an LCD HDTV.. save desk space and have improved picture.
However what are the LCD HDTVs like with the computer, for web browsing etc? Also, are they bad on the eyes? Because i will have to work at my computer.
I really like the price and look of the Samsung HDTVs. But if theres other opinions/advice it will definitely be considered. Currently looking at Samsung LE-23R51 (HD-Ready) but not sure on the connectors (Dsub is that VGA, and Video in/out my aerial?). Its a bit irritating we cant link out, but if you advise on the type/model of product i will find it online.
Any advise is much appreciated.
