what memory to get for macbook upgrade.
13 Jan 2006
Wigan
wanting to upgrade my memory in my MacBook Mid 2010.
currently only have 2gb not sure what to get.
can it take 2 x 4gb?
help please :p
help please :p
They happily go up to 8 (and it really helps).
I personally use Crucial (I think most other people do as well) and at work we use Kingston for Macs and have had no issues with them either.
My old 2010 iMac (uses same ram) was recently replaced by apple so I kept the ram I added my self.
If only I could access members market, I'd be able to sell cheap,since its lying around being wasted
and yes it takes 2 * 4gb. Apparently also 2 x 8gb.
It goes up to 16G ?
went to my local shop today to get the memory. i saw corsair macmemory for only a couple £ more than the crucial stuff claiming mac compatible with macbook, macbook pro and imac. so i thought i will get that as it is 'guaranteed' to work.
2 x 4gb sticks same specs as the crucial but already tried and tested with mac.
installed it and i get a single beep upon boot meaning memory problem.
tried all combinations but i still get the same response.
put my old in and it works fine.
looks like i shall be taking it back tomorrow!
should have taken mine :D
Yeh Crucial is your bet bet though.
