Consendor/Dynamic
he complete kit includes:1 RV6 Microphone
metal shock-mount
alternative stand mount
sturdy plastic carry case
foam windshield
spare shock-mount elastic.
Specifications
- Element: Pressure Gradient Transducer
- Diaphragm: 3-micron thick, 1” vapour deposited gold diaphragm
- Polar Pattern: Cardioid
- Frequency Range: 20Hz – 20kHz
- Sensitivity: -36dB (+/- 2dB)
(0dB = 1V/Pa at 1kHz)
-Output Impedance: 200Ù +/- 30% (at 1kHz)
- Self Noise: 15dBA
- Max. Input SPL: 130dB (at 1kHz 1% THD) when phantom powered
- S/N Ratio: 79dB
- Phantom Power: 48V D.C.
- Bass Roll-off: 100Hz/oct 12dB
chris_r said:Thanks guys;
It is for home vocals, no instrumants would be plugged in etc
How does this sound for a mic? it costs £50
If you want a link add me to MSN [email protected]
Do OCuk sell mics????benneh said:Impossible to say without hearing the mic. Personally I wont record vox/acoustic or high dynamic stuff without a decent condenser. But the shure sm58 would be ideal for you. It's proven inductry standard, so your money will probably be best spent there.
) - any suggestions as to what I should use to raise it to a normal volume level? Should it be some sort of preamp that sits between mic and PC or should I be using a more specialised input on the PC itself?Chronos-X said:I've got a SM58 but the output is very low when feeding into my PC. (XLR->Minijack cable) - any suggestions as to what I should use to raise it to a normal volume level? Should it be some sort of preamp that sits between mic and PC or should I be using a more specialised input on the PC itself?
. I'm suprised you got much at all as it is. Try a cheap behringer one for a start, you'll get the advantages of low noise pre-amplification, EQ, a balanced mic lead (though you may already be using a balanced sound card?) and complete control over the levels. Worth buying one with phantom power btw. I bought mine with no intention to use it, but I use it all the time now for my mics
